2004 Yamaha ar230 rattle noise
An31480
2004 Ar230 Rattle noise from both engines? Does anyone knows what it could be. I change the intermediate bearings, spark plugs and still is rattling?
Acard7
SW Iowa
Are you running on the hose or are you hearing it in the water too?
Acard7
SW Iowa
Ahh ok I was going to say mine sounds like it rattles out of the water but in the water it’s smooth, check your pumps. Pull them and check the impellers and wear rings, see if they are catching somewhere
An31480
Ok thanks for the the advise.
itsdgm
Do you have a video of the noise?
An31480
I’ll take one. The Engine does turn On, but it is a milky oil, so I took the spark plug out and on the 3 that’s were it squirted water
