2006 AR230 motor seized up
Tim Riley
I'm not sure anyone can help me, but after having my starboard engine rebuilt, and only using it a few hours last year, it seized up. It sounded a little noisy, then abruptly stopped. Took the boat home. Check if it would rotate and it wouldn't. Pulled the plugs and number 1 and 4 were high and equal. Plugs 2 and 3 were not equal depth. They were about an inch different. I believe those are supposed the on the same plane. Should I have it rebuilt again (another $3000) or buy a new engine from somewhere?
Thanks,
Tim
HangOutdoors
Royal Oak, MI
was there a warranty on that engine you had rebuilt? Awful short time for the engine to seize. Could be poor rebuild.
zipper
Boston Whaler
Sounds like who ever rebuilt the engine, may have put a heli coil insert into to spark plug hole to make a repair to the head. Can't buy new but might be able to find a donor jet ski with the same engine.
Edit: All 4 plugs are the same # ? An inch is a lot.
Tim Riley
Edit: All 4 plugs are the same #? An inch is a lot.
That's why I think it broke a piston rod. I put a long screw driver in the spark plug holes and measured each one. It was about 1 inch difference between 2 and 3. I'll check the heli coil idea. thanks
zipper
Boston Whaler
Oh, you were measuring the distance from the top of the pistons to the top of the spark plug holes. I misunderstood, forget the heli coil idea. You have a bent or broken rod as you thought.
