2006 sugar sand 240 EFI MERCURY JET DRIVE
Jmiah
Sugar Sand
Tango Xtreme
I’m getting 4 beeps every 2 min, can anyone out there help me with this? I’ve replaced the direct oil Injector on the side. Still beeping, it’s not overheating, runs good but beep keeps going on.
2006 sugar sand jet boat 240hp
Bilmon
freeport il
Sugar Sand
Mirage
Hi Jmiah, welcome aboard. Four beeps every 2 min is either low oil in the reserve tank, the small one on the side of the engine, or water in the separator, the oil filter looking one just below the oil reserve tank. The switch in the oil reserve tank can also go bad and cause it. Cure for that is you have to replace entire tank. Overheat is continuous beeping until the system shuts you down.
