2006 sx230 Middle Injectors not working after fast idle goes down
vollender
Chaparral
I have a 2006 sx 230. When starts up all 4 injectors will spray. When fist idle stops the 2 middle injectors will not spray. If I shut off for a few and pressure backs off then start all 4 will spray then stop after fast idle goes down. I put 2 different injectors in the middle and the same thing.
Is this a ecu problem
More than likely, yes! Swap the ECUs and see if it follows.
Is ecu in black box on back wall
Yes, it's in the big black box on the back wall of the engine compartment. It's a LOT easier if you have a second person to hold a wrench from the back side. (you need to remove the cleanout tray on the swim platform to access the back side) Otherwise, it's not too bad.
You could also swap ECU's with the other engine, just to verify the problems follow the ECU. It's a simple and effective way to troubleshoot things.
