mckev
- St Petersburg, FL
New to me 2007 AR230. Bought with 103 hours a month ago.
First outing it overheated the starboard engine with light flashing on the dash, wouldnt go past 8k RPM. Port engine was fine, but both pissers were clogged.
I did the closed loop acid flush and replaced the thermostats.
Next outing the starboard engine light flashes on the tach on first start on the water. I turn off and restart a 30 seconds later and the engine flash doesnt return.
Run for 2 hours on a lake and both engines are hitting 10k and cruising without issue.
Next outing on the Gulf of Mexico, same thing, starboard engire fires up and starts flashing the engine light on the tach. Turn off and restart and the light never returns for the day.
Get it home and connect up YDS for the first time.
No record of the first overheat event from outing #1 and no record of the engine codes...
Any ideas? I have YDS 1.33 (eBay version).
