tdonoughue
- The Woodlands, TX 77381
When you installed the impellers, before you connected to the splines, did the impellers turn freely? Do you have a gap between the impellers and the ring all the way around? There is a spec for that--it is very small, but important that there is a gap there. I thought I saw scrapes on the ring in the photo. If there is contact and the engine is fighting against that, you could get lower rpm as you describe.
Mind the gap.
Mind the gap.
