2007 SX210 Spark plug issues
jgn1013
My port engine spark plugs look like this after only 20-25 hours of use. The ECU has been replace with an used one, but I'm still seeing the same issues, anyone have suggestions on how to fix this problem? I even switched the ECU out with the starboard engine and still same problem.
buckbuck
Texas
I would recommend checking the fuel injectors.
WREKS
Port Saint Lucie, Florida
I do not see the problem. Please, explain!
212s
1000 Islands
212S
check the fuel injectors for what?
Sticking injector - the plug indicates it's running a bit too rich. Are all your plugs too dark, or just one? If just one, a sticky injector is pumping too much fuel into the port.
Sumokatoom
Possibly a bad stick coil(s). Move the stick coil(s) to the other motor and see if it follows it.
