flyin_dutchman
- OKC, OK
- X
Took the boat out a week ago and low and behold, the ballast pump didn't work? No light, no power to switch? So I have no power to the factory ballast switch down by my right foot on bulkhead? I have checked all the connections to the battery, everything else on dashboard is working, lights, blower, etc. (except horn, which has never worked for me)
I'd like to start the troubleshooting from easiest to hardest, and find the fuse for the ballast but not sure where it is located exactly? If not the fuse. then I will swap out the switch, then go from there if still not working....fingers crossed.
Thanks in advance
Dave @ OKC
Thanks in advance
Dave @ OKC
