2008 212x Speedometer not working
libton2003
212X
Hi Everyone, I'm coming back to the forum to seek guidance because you all are so helpful. So yesterday out on the lake, we beached the boat a couple of times to let the kids play. When we were heading home for the day, I noticed the speedometer was reading zero. I did some reading on the forum last night and think it could possible be the wheel on the back of the boat was damaged - or hopefully just has some sand/dirt in it making it stuck. I am going to look at it later this week and see if I can diagnose it. Do you guys have any hints or tips that I should keep my eye out for? Thanks in advance!
Russell
Round Rock, TX.
212X
Make sure the mount is not loose. I've found this pinwheel works best if it's angled down just a bit in the back to allow more bite
it the running water. (You may have to trim it some or shim the upper lip) Also clean it with Lime-A-Way cause that wheel needs
to move freely in the water. The lake I run has a lot of hard water.
buckbuck
Texas
And you may want to consider spraying it with silicone spray.
libton2003
212X
Thanks, everyone for the tips. I haven't made it out to see the boat yet but plan to do so in the next couple of days.
libton2003
212X
Hey guys, yesterday we took the boat out and I checked the wheel, there was some dirt caught in it. I flicked it and it started spinning freely. One of the vanes is off but it doesn't look like a fresh incident. Out on the water the speedometer worked well! Thanks to you all!!!
