Watts-Up-Cyclist
Need confirmation and/or clarification.
I need to buy the steering cables, using my improved search skills, I found parts numbers SEASTAR-SSC21917 and the OEM part numbers F0R-U1470-00-00.
Are both sides (starboard and port) cables the same length of 17 feet? I question it because some say the used the same cables on both sides and I found a part number F0R-U1470-10-00 which is different from the previous one. I also found one post saying that one is 1 ft longer.
Thank you in advance.
Troy
Navarre, FL
Troy
Navarre, FL
