2008 Yamaha 232
Michael Blais
West Michigan
Limited
So the port engine will not start. No ground pulse to the injectors. ECU is good swapped it with starboard engine and it runs fine. Engine will try to start or run momentarily if starting fluid is used. So I have spark but no ground pulse from ECU?
