2010 yamaha vx cruiser hep
WOOSAB
Mansfield, Texas
I need some help from some of you experts. I'm having problems with my 2010 Yamaha vx cruiser. It wont go past 35mph and I am stumped as to why. I have changed out the plugs 2xs. I have pulled the impeller and no damage. I have changed the oil and oil filter. I have checked the air filter and it's clean. The rpms still goes to 9 or 10k don't remember off top of my head. Which leads me to believe its not the motor but something leading to the impeller. Love the motors and the light maintenance but I am stumped. Any suggestions on where I should start?
Thanks In advance guys.
robert843
Myrtle Beach, SC
My first thought when reading was to check the key and make sure you are not using the learning key but if you are hitting max rpm that wouldn't be the case. Check the wear ring and make sure the impeller isn't rubbing it.
WOOSAB
Mansfield, Texas
checked the wear ring and there isn't any damage or to it. Very smooth. I opened 2 others up to make sure the ones working correctly looked the same.. we have 5 of them as well as a Yamaha 232 so no expect but I tried to cover all the usually stuff before posting but after a week it has me scratching my head.
robert843
Myrtle Beach, SC
Next I would use the remote try toggling in and out of lmode to make sure it's not stuck but I don't think that's the case if the rpm's are that high. Maybe clogged injector or fuel filter I would check those. Another easy thing to check is try running the ski with the seat off if it has a small exhaust leak it could bog it down but with the seat off it wouldn't
