2012 242 batt volt only on one motor
Rican3kgt1
Hello like title stated, went to take the boat out yesterday and one motor would not start due to batt voltage code. I did charge the batteries prior to leaving completely. When I try to start I just get a single click so not sure if it is the starter with that code. Also when I would try to start the coded motor it would throw the motor running into a limp mode which would barely run. If I reset the battery switch, the running motor would be fine. I tried to look for problems at the house and did notice that my voltage sensitive relay module had been corroded pretty bad. I do charge each battery independently so still don't know if that would affect it. I have read to try new batteries but I would think it would affect both motors not just one, I don't know. Thanks in advance.
Make sure all your grounds are tight and clean. To me when batteries test good, it most likely is a ground or connection issue
