2013 Yamaha 242 Limited S Harness help needed
OrlandoGuy
Orlando FL
Has not been used in salt water, boat is very clean, but the other day one engine would not start. Local mechanic checked everything including shifters neutral switch, cleanout hatch cut off, starter, calanoid, computer, fuses etc.. in tracing wires, he discovered some wires had some melting and corrosion in the harness midway between the port and starboard motors.
