2014 Scarab 195 HO
jkirk30
195 ID
Hey guys!
I’ve searched for what I’m specifically running into with my boat and haven’t found the same issue.
Recently had my super charger rebuilt, throttle body replaced, and O2 sensors replaced. After getting the boat back it ran great then I got a code for bad fuel. Ran some fuel cleaner through it and it ran fine.
Now the boat won’t go over 5k rpms or over 10mph with the engine compartment closed.
i was running the boat and had my son take control while I checked the motor to see if I could hear something with the engine compartment opened. After opening the compartment for a few second the boat jumped up to 7000+ rpm’s and was running as it should. At that point I closed the compartment and after a few seconds it dropped back down. When I open the compartment it runs as it should like it’s finally getting enough air.
I replaced the air filter and still having the same issue. I removed the air filter and covered with clothe to see if maybe the filter I was using was restricting the air but that wasn’t the case.
What could this issue be? I’m thinking it’s possibly a tune issue? Any suggestions would be greatly appreciated!
NOTE: there are no codes, warning lights, or cavitation issues.
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
Definitely odd. I'm intrigued.
You had a bad fuel code? I've never heard of that. What was the code?
I doubt it's a "tune" problem. Way more likely it's a fuel or spark problem. Air issues have just not happened on these boats. Not saying it's impossible, just not a thing. So I'd concentrate on fuel/spark. I think your engine hatch opening/closing is a red herring. But I've been wrong before... lol.
Start with new spark plugs. Those are super inexpensive and it's a quick thing to do. Ignition coils may be another thing.
The fact you think you had bad fuel... I assume that stuff is still in there? You could get it out and put fresh fuel in there as well.
Some stuff to start with. Please report back as you troubleshoot.
