Tommy Lee
- Scarab
- Other
I think water is coming in around the transom seals. I noticed after taking the boat out on Wednesday that after opening the plugs it took an unusually long time for the water to drain. So I started thinking... we purposely lodged the boat on a soft shallow sand bar where we like to hang out. I'm thinking that the sand jarred the jet/reverse bucket, which then jarred the transom seals slightly loose. The other possibility is rain water getting in the boat, but I don't think that's the case, as the factory top is fabulous.
Someone tell me, is it dumb to lodge a jet boat against a shallow sand bar? If I did cause the transom seals to become loose because of that, then I would say I'm an idiot. My question then is, should I completely remove the jet assembly and transom and reseal it? Or would it be effective for me to just remove the jet assembly and put additional sealant around the existing transom seal?
Fyi, last year we got a tow rope sucked into the intake, destroying the impeller boot on the impeller shaft. I removed everything and repaired it with a new $12 impeller boot, so I'm fully aware of how to disassemble and assemble the entire jet apparatus back there. Looking for some input.
