2014 yama/212x - no water out of Starboard Motor Pisser when flushing??
Ratket
Lake Havasu City Arizona 86406
So I just went to flush and I’m. It getting any water out the starboard pisser, port sign is flowing fine...any thoughts?? Thanks all
swatski
North Caldwell, NJ
Mud dubbers like to burrow in there. Try a weed wacker line, or access it from the inside, not too bad.
Is water flowing out of the pump, is it cooling on the STRBD side?
Ratket
I pulled the line of the motor side and turned the water on and I got water, I can blow through the line so no obstructions, could it be a water pressure issue? I got water coming out everywhere else but the pisser.
haknslash
Lake Martin, AL
Moomba
For me to have good flow out of the pissers I needed 65-70 psi at the spigot from my house.
Are you running both engines off the hose or one at a time?
Ratket
One at a Time, at best I have 60 PSI, plus only hose I had available is one of those flex hoses that expands under pressure... why I think it may have been a pressure issue, but the port engine was pissing water when I flushed it.
