FLJetBoater
- 242 Limited S E-Series
I went to accompany a survey on a boat I'm looking at buying and there were a few issues noted. Some are minor (as in fixable) items like corroded hatch lifts, missing nuts/washers inside the engine compartment for the aft seat cushions, etc. Stuff like that I don't mind fixing up. Only 80 hours on port engine. Starboard tach wasn't working so no read on that engine. Speedo and starboard tach not working - $600 in parts from what I gather, as long as it's only the gauges. What's the chance it could be something more?
However, I'm more concerned about some of the corrosion. The boat is near salt water and probably was used in it exclusively, but trailered. One of the outdrives is missing paint on the bottom but they do look in great shape. Many hose clamps are extremely corroded (seems easy enough to replace them?)
Engine performance was all good. 7100 max rpm WOT.
Edit:
I renamed this thread, as I'm walking away from that other boat. I've upped my budget a little bit and now have 2 boats on my radar. Both look in amazing condition and will be seeing them tonight. Both are basically the same price and both < 80 hours. 2014 242 Limited S and 2017 AR240. The AR240 does have a much nicer helm. The 242 has fresh water, better cushions.
Does the 2017 AR240 have additional noise deadening? Was that applied to all models starting in 2015?
I'm super torn...
Edit:
I'm super torn...
