MichaelN
- Scarab
- HO Impulse
Was hoping someone could help steer me in the right direction as there are NO Scarab mechanics around my area.
I have a 2015 Scarab 195 HO Impulse with about 245hrs. Recently I have have been experiencing the boat being very sluggish and running rough during low speeds.
Typically I was able to run the boat around 38-40 mph at top speed. Now it only runs a top speed of 24 - 26mph with WOT at 6000 - 6100rpms. Then at lower speeds, closer to no-wake speed the boat runs pretty rough, almost like it is missing. At WOT the boat is smooth, just not cruising at its full potential.
Recently the oil pressure sensor was replaced due to a code and the boat running in lump mode. This fixed the limp mode issue, but immediately after putting the boat in the water, the recent sluggish performance was noticed. Under the suggestion of a mechanic, I had the spark plugs replaced, but no difference.
It almost feel like there is no boost as I would typically hear and "feel" the supercharger kicking in.
So, I feel like it is a supercharger issue, but wanted to get some advice from fellow Scarab folks to see what possibilites there are to explain this. Is there a good way to "self diagnosis" this problem?
The last time I took the boat into the shop (3hr drie away) with a small oil leak, they replaced an o-ring and a small plastic valve. The parts...$197. The labor...$1900. So as you might guess...I am not eager to put the boat in the shop right away without at least some idea of what could be going on.
I am trying to sell the boat, but want to be honest with anyone that might want to purchase it. BUT if the fix is relatively inexpensive I might consider keeping it.
Any ideas and/or help would be greatly appreciated!!
