2015 SX210 oil change
Michigan
New member and new owner of a 2015 SX210.
The boat has 100hrs on it and my son and I performed the 100hr service tasks.
The motors are the 1052cc variants.
We used an oil extractor after running each engine for 10 minutes hooked up to a water supply to bring the oil to operating temps.
We managed to pull-out 2.25 quarts per engine.
The owners manual is slightly vague stating there is 4.5 total quarts of oil.
Does this mean 2.25 per engine?
I’m assuming so.
Michigan
After further research it seems the 4.5 qts. Is each engine.
I will have to try to extract more oil out.
gt5pilot
Lakeway, TX 78734
Part of that 4.5 qts of oil is in the filter and in the dry sump tank - to get all of it out you need to drain the block. You have evacuated the oil that is in the top part of the oil cooler - I think there is a small hole that allows you to get deeper in the cooler with the evac.
VitaminSea
Central FL
On the MR-1’s, I usually extract around 2.2-2.25 per engine. As pointed out above, you will not get the full 4.5 qts unless you drain the block. Here’s from my service manual…
