2016 242 JL Audio 7.7’s all around
Hector
Mechanicsville , Virginia
0A289179-5DF3-411F-B4F3-F3A98120A2EC.jpeg 683BB2D6-62B6-4879-8261-01A7425AFD8E.jpeg 775B4714-B9F5-4E63-97B3-5A8D7B7D22A7.jpeg EBBA94DF-921D-43C9-9D00-15B1FB2913BD.jpeg 33698DC3-214C-494A-9DC1-6BBD1C5963B1.jpeg CD903212-4EE0-40B7-8C01-99169DCF5336.jpeg 95DFADCE-B57C-4253-9ABB-61A2B0112F36.jpeg 970D6192-85F1-46AA-903E-8CC78FB5AA25.jpeg AF8DC102-4E9D-4BEE-911B-1B2A4252D62C.jpeg E1FBFE05-5019-4321-8A6F-15BE568D330C.jpeg F9C9228F-AB16-4F1A-A09A-C464306D82C3.jpeg 8988F547-68D2-452F-BCAD-FAA77A2E26CB.jpeg C3CBD8D3-DA32-44EC-BB0A-BFAEBD19EEF9.jpeg 103D20AA-0164-433C-A164-97FD137BA503.jpeg 233AFB7C-2D27-4711-B57F-8D59C381A3F6.jpeg Amps and 12” sub in helm, second 12” sub is in a box in the compartment behind the driver seat.683BB2D6-62B6-4879-8261-01A7425AFD8E.jpeg 775B4714-B9F5-4E63-97B3-5A8D7B7D22A7.jpeg EBBA94DF-921D-43C9-9D00-15B1FB2913BD.jpeg 33698DC3-214C-494A-9DC1-6BBD1C5963B1.jpeg CD903212-4EE0-40B7-8C01-99169DCF5336.jpeg 95DFADCE-B57C-4253-9ABB-61A2B0112F36.jpeg 970D6192-85F1-46AA-903E-8CC78FB5AA25.jpeg AF8DC102-4E9D-4BEE-911B-1B2A4252D62C.jpeg E1FBFE05-5019-4321-8A6F-15BE568D330C.jpeg F9C9228F-AB16-4F1A-A09A-C464306D82C3.jpeg 8988F547-68D2-452F-BCAD-FAA77A2E26CB.jpeg C3CBD8D3-DA32-44EC-BB0A-BFAEBD19EEF9.jpeg 103D20AA-0164-433C-A164-97FD137BA503.jpeg 233AFB7C-2D27-4711-B57F-8D59C381A3F6.jpeg
I was asked to post pics of my sound system since it appears I am probable one of the few with JL Audio 7.7”s all the way around.
My system consists of 6 MX 7.7’s in the boat, w M 7.7’s in the swim platform, 2 wetsounds icon 8 towers, and 2 12” jl w3 subs. It is being powered by 1 JL Audio M600 6 channel amp and 2 JL Audio M700 5 channel amps, all thru a wetsounds 420 eq.
I have radio and all sound equipment going thru a small fuse box inside the helm to where I don’t have to turn on any battery/house switches to run the stereo. The 4th switch is a voltmeter and 2 usb charging ports.
The bilge switch powers my secondary pump that is connected straight to the battery and I can also manually turn on from this switch.
My set up has 3 batteries. One group 31 starting battery and 2 optima blue top group 31’s wired in parallel for stereo and accessories.
It has all been trouble free for the last 2 seasons.
Jaylex
Nice setup my friend....I was mistakenly told that 7.7s would require additional mods....guess I was misinformed. Thinking 7.7s will be coming to a AR240 near you,lol
What kind of box did you find to manage into the helm....when the door is shut now well do your vents pass thru the sound....I have my 2nd 12 in the port storage will likely port that side since I have it setup already...what's the link to those vents you used?
I'm sure it sounds great....good to know that 7.7s fit...
I envision a boat full of M770s....and two pair of 880 towers!!
Thanks for posting. Looks like a solid setup for years to come....any further mods you want to the system?
Drift Away
Amps and 12” sub in helm, second 12” sub is in a box in the compartment behind the driver seat.View attachment 71937 View attachment 71938 View attachment 71956 View attachment 71957 View attachment 71958 View attachment 71959 View attachment 71960 View attachment 71961 View attachment 71962 View attachment 71963 View attachment 71964 View attachment 71965 View attachment 71966 View attachment 71967
How did did you get the 7.7 to fit up front? I looked at that when i started my upgrades and say that it sat in a pod made for a 6.5.
Hector
Thanks, here is a link to the vents I used on the slanted part of the helm to get the sound out. I just painted them black.
https://www.google.com/search?q=seiho+sx-6&client=safari&sa=X&hl=en-us&biw=375&bih=635&tbs=vw:l,ss:44&tbm=shop&prmd=svin&srpd=2916218441454824799&prds=num:1,of:1,epd:2916218441454824799,paur:ClkAsKraX-Abv4H74Xe_PbhlE1WngpWm2VJCe4syXeoYuPyLEpvbPoI7qYclS-GW_MONb7clHJf3SybfTUf57nZ3-ZSYLntAKqrKNvOb-4iUCl-nuSn0C_vydxIZAFPVH72RHEzAZT_2A9thWB0-eFKhSY10_A&ved=0ahUKEwjvgMjg0bnaAhVyplkKHdPZCJEQgjYIpQI
I just added a picture that shows both the vents for the rear sub.
The front speakers did require a 1” spacer though.
The box was custom made to fit at the helm.
Only mods I just did was the switch panel for my accessories. Main reason was when beached you’re in really shallow water and my transducer alarm would start beeping once in a while. Now I don’t have to turn on the connext screen to turn my system on.
Hector
The front is the only place where a spacer was needed. If you look at the pics closely you’ll see it. It’s 1”.
swatski
North Caldwell, NJ
You wouldn't have any install pics, would you?
The bow is definitely an area that could use that kind of an upgrade!
In fact, in my setup it is the only one that would need any attention.
Drift Away
Dont be scared. Cut some holes lol
Hector
Here is some close up pictures where you can see the spacers.
Unfortunately I don’t have any actual install pics.
Even at that the front is weak in comparison to the rest of the boat. I have a spare set of mx 7.7 that I’ve been thinking of adding at each fr compartment and wiring in parallel to the existing speakers. Then again I never ride or chill in the front. Only time I’m ever there is to drop or retrieve anchor,
JeffVans
Zion Crossroads, Va
Why were the spacers needed? Because the baskets were too deep? I think they make a "slim" version of the MX6.5s, I wonder if they also have them for the 7.7s?
Hector
no clue if they make the smaller basket for the 7.7's.
Yes, the speaker was too deep and would not fit in the "pod"
JeffVans
Zion Crossroads, Va
Well... Looks like you have to upgrade to the 7.7s now... Let me know when you want to sell those tiny old junky 6.5s!!! bwahahahaha
Jaylex
I'm glad someone was able to clarify that 7.7s will fit...now I wish my original installer would have confirmed that for me, could have saved me some money, lol.
@JeffVans not sure if your serious, but I am actually looking to start to swap out some of my JL MX650s for 7.7s. If your interested in the MX650s let me know. I will eventually post them on the classifieds section.
I have both white and black( total of 4 pair). Bought them brand new from my authorized dealer last May, and they have seen a handful of trips and not even close to being abused. Boat is stored indoor and always babied. One set (transom) was installed a few weeks ago brand new and only played once.
If your interested PM me and we can work something out.
@Hector how are you powering the M770s on the transom, and can you tell the diff between their output and the MX770s?
Drift Away
I loved my 7.7s from the moment i put them in.... Until @wallacerb unleashed a pair of 8.8 pods last weekend. I Strongly encourage anyone who can afford to go out and buy a pair or 4. Its night and Day different. Only problem is each pod takes 200 Watts to push.
Jaylex
@Drift Away what are you pushing your 7.7s with? Did you notice a diff.
And I echo your comments....my 880 towers are music to my ears and I have 200rms going to each of then..I'd love to add 2 more but not sure I want a crowded tower,unless I can put them outside of the existing ones... I've hit my head already....decisions decisions
Hector
yes, there is a difference. They sound cleaner with more presence at least in my opinion. I might swap out all my amps and mx 7.7 during the winter.
I have 2 JL m700's, one with sub channel to one jl w3-2 ohm and the other 4 channels bridged to power the westbound icon 8 towers.
The other JL m700 with the sub channel powering the other jl 12w3-2ohm with the other 4 channels bridged to power the jl m770's at the rear swim platform.
The JL m600 6 channel powering all six jl mx 770's in the boat.
I have a couple of JL 12W3-4 ohm that ill sell cheap if anyone is interested. just PM me
Drift Away
I have 2 600 JLs pushing everying. So the 2 subs are getting 200 and the 7.7s are getting 100
Jaylex
@Hector sounds like you might be looking to upgrade as well....all M770s? what would you power them with?
@Drift Away how do you have your 7.7s getting 100....thats what Im looking for...
Why dont JL make some amps that do 100rms @ 4ohm
My struggle is to add 2 more 880 towers, or beef up the 650s to 770s
Hector
Just add another M600 and another group 31 blue top , lol
Drift Away
The 2 JL600 6 channel. 2 channels per sub and the rest of the channels are pushing 100 watts each. One channel per speaker.
Jaylex
Damn....4 amps....smdh...that WAS NOT part of the plan, lol
Back to the drawing board.
