2016 242 Limited “Float Mode” Question
treeskier
Ocean City, MD
So first full day out on the new boat and I wanted to make sure I understand float mode.
I have the start battery switch and emergency battery switch off and the house battery switch on. I can’t seem to get the context to activate unless I turn the manual blower switch to on. Then it indicates float mode and the blower, bilge and stereo are all active.
Is this telling me to run the blower whenever I’m in float mode?
Thanks.
spwns105
With your house battery on, if you hold the sys control button for a couple seconds, it should power on the electronics. Can't remember if the key has to be in the on position or not.
MidnightRider
Zumbro Falls, MN
Malibu
Wake
Yep, push and hold the Sys button - and no key on needed. If you want to turn the connext screen off again without using the battery switch just toggle the manual blower switch on and off.
treeskier
Ocean City, MD
Awesome ...thank you very much
treeskier
Ocean City, MD
Thanks thats a big help
treeskier
Ocean City, MD
