gunk12
- Limited S
Noticed that one engine is only producing 6100 RPM at WOT. Checked clean out and impeller. Check APS throttle linkages. Oil level is OK. Next I’m going to change spark plugs and if that doesn’t resolve issue I’m going to run without air filter to test. Filter looks good though. Anyone have any suggestions on what else might be the culprit before I pull the boat to the dealership and spend lots of $? Thanks for your help and advice
. At sea level, 300 hours on the engines. Other is hitting 7100rpm. Top speed now is only 36mph.
