Kbeats103
- Yorktown, VA
- 242 Limited S E-Series
After shutting down my port engine post-flush (and prior to turning off the key or the batteries), I received the "Gateway Comms Error" on my Connext - exactly the same symptoms as Julian described in his post:
2016 242X connext "gateway comm error"
Symptoms:
1. "Gateway Comm Error" on Connext (won't clear and audibly alarms every 5 minutes)
2. No fuel tank level indication (instead of a %, it shows "NC")
3. No speed indication (shows "Err" instead)
4. Polk Audio system won't turn on nor connect to bluetooth
5. No power at the passenger USB connection (tried plugging in my iphone and it wouldn't charge)
6. All other systems normal (engines, throttle control, etc.)
I went through Julian's post and troubleshot the potential issues I learned about from that post; I've verified my batteries are supplying sufficient voltage and all connections are tight, the two 20a micro fuses are satisfactory, as is the 5a micro fuse in the battery locker fuse panel.
I ran the boat for a few hours yesterday just to get out on the water, and one unusual occurrence while underway is that this "Gateway Comms Error" cleared and all indications on the Connext screen were normal for about 1 minute, and then the error came back in and stayed in. This leads me to believe there is a connection that is loose or otherwise degraded than when connected for the brief period, made the system work properly.
Anyone else out there have this problem and able to determine what the gremlin was? I know Julian narrowed down his issue to the fuses described above. I've also read some of the forums that indicate the issue could be from the GPS and/or the port tachometer, so I'll search there too. Is there a wiring diagram out that shows what ties into the Gateway network? I have the tech manual for the boat, and while there are accurate tables that describe what wires are in various wiring harnesses, I haven't found a comprehensive wiring diagram that shows what is connect to what.
I'm taking a stab at troubleshooting the electrical systems myself before I try to find a dealer (I bought the boat used from a private seller), so I'll document what I find as I go. I'm just hoping someone out there can narrow down my search to save me some time!
Thanks everyone!
Symptoms:
Thanks everyone!
