2017 AR240 bilge pump issue
Ashley02049
We recently noticed that our bilge was red on the connext (showing error code) and we had water. Replaced the bilge pump, and the error code is still red. Is there a fuse we should be looking for? If so-where is it located? Any other suggestions? There is a fuse box next to battery (I’ve attached picture) all are in and working. any help would be appreciated
I’m having the same issue. Did you resolve the issue or find a fuse?
Did you ever figure this out? Having same issue with my 17ar240
I replaced bilge pump same result, light goes red and it clicks and never kicks on, has to be power or fuse somehow?!?
Hi! After replacing the bilge, we were able to get the manual bilge to work when we hit it on the screen, but not the auto. It still goes to red. We just have to check it every so often. All of our fuses were fine . If you find any info, please share bc it’s frustrating!
Ending up flipping the brown wires off the new bilge pump (from partzilla said was Yamaha part) and it works fine. One was short and cut off, one was in the gray harness plug, I just cut the one and connected the cut off one instead to the gray plug, and all good now. The one brown wire handles the manual and auto functions both, no clue what other brown wire is for, just bazaar I had to switch them on the harness provided, but all good now:)
