2018 210 FSH Drain Plug???
I know You know
South Florida
Does anyone have any idea of the diameter size of the drain plug on the 210 FSH?
Thanks
Liveto99
New York Hudson Valley
It is 3/4" when measured with a caliper
It is plastic and seals with a O ring
Liveto99
There is no size or part number in the service manual for the plug. But there are 3 the same so they should be the same as the ones inside the boat if you need one right away. It does not look like you can change it out on the FSH 21 sport. The threads do not look like they are NPT so you might have to get one from Yamaha. I will look for the electric connections when I get home from work.
