2018 Scarab 215 - CTSY/Docking lights not working
mcavoyd
215 ID
Just purchased boat and trying to figure out why the CTSY/Docking lights are not coming on when I toggle switch on dash. Anyone know what fuse I can check for this issue? Or any other suggestions for troubleshooting? Thanks
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
Lights are obviously very simple. The fuse definitely should be your go to starting point. I don't know where your fuse boxes are located on your boat, hopefully you do. But here's the layout.
mcavoyd
215 ID
Update: Ended up being connecter to toggle came off. Appreciate the help with fuse box.
Edgeman66
215 ID
I had the same problem with the connector being disconnected.
Nimshouse
195 ID
Have same problem, but not sure how to access this connector you mention. My fuse is fine, and the toggle switch lights red when I switch it on, but no blue led courtesy lights.
Edgeman66
215 ID
If the toggle lights up, it is likely not the connector. But the connector is on the backside of the toggle switch. Lift up the seat in the bow and detach the snaps that keep the vinyl sheet protector between the cavity and the control panel. You should see all the wiring harnesses and equipment in there.
