2018 SX190 with trailer (spare tire)
Dwrat
I just got my spare tire I put it up against the original trailer tires and it's just a hair higher than the original Tire would that be okay to use for a spare?
Yes, that will be just fine.
I would be more concerned that the bolt pattern is correct.
A quick test fit will answer that question.
haknslash
Lake Martin, AL
Moomba
Yes most likely. You would need to have a fairly larger sidewall size to worry with touching the fenders, which btw can be modded to be raised if need be.
W3bexec
Greeley, CO 80634
Swapped them to radials and it was night and day difference in towing. Very much worth the upgrade.
Amen. Bias ply tires totally suck. $30 piece of crap tires rolling our $65K+ boats. Ugh. Geez, its not a wheelbarrow.
Fordman
Westmoreland, TN
got new wheels put on today on my 18 AR190! Recstuff.com is the place to shop.
muzhik
Fordman
Westmoreland, TN
Just rims. They are 5x4.5 lug pattern and 13 inches. I bought Carlisle radial HD 185/80r13 load range d. These radial's ride so much better than those stock bias ply's
muzhik
Thx.. looking at my stock, they are 14'.. i do have ar192, but trailer should be the same.. hmm. can anyone pitch in if 14' would fit and not rub?
