2018 Yamaha 242x tower pins plastic insert stretched
jakew7881
I have 2018 242x and one side of the tower rattles whenever we hit a wave. We checked everything and everything on the tower is tight. The part that is making it rattle is the plastic insert that the tower pin goes into. It appears that the plastic has been stretched and the pin no longer fits tight which causes it to shake. Anyone know if this plastic can be replaced? I can’t find it on any of the Yamaha tower parts diagrams. Picture attached for reference.IMG_8995.jpeg
That's the same tower and latch I have on my 2020 - try this:
Did you or anyone replace those and eliminate the rattle ?
I replaced one in a 2016 242x..hated that rattle..then the pin wouldn't go back in. Put the old white sleeve back in and wrapped a simple piece of foam over the internal base part, poked a hole in it (so the pin would go through it), put the tower back up over it and put the old pin back in. problem solved!
Mine doesn't rattle - btw after reviewing your photo again I may have given you incorrect information. Your 242X tower looks much larger (and has a shock) than my 212S tower...
I suggest a fix like Rodder77 stated - you might be able to modify a pool noodle to eliminate the rattle.
Pool noodle is way to thick, you wont be able to close the tower back down over it, I used a simple piece of foam wrapping that furniture or electronics comes wrapped in to protect it in the box during delivery, probably from something I ordered from amazon and was left over packaging. see picture - the piece i used was just longer to wrap over the base and poked a hole in both sides. Been on there a couple seasons now.
Great info cant wait to try this out it freaks out passengers with the rattle sound it makes. The First boat I looked at and water tested had that tower and the rattling sound made me think something was wrong
So this is the concept? Can't wait to try it out
Exactlty! just wrap the foam over the metal base, covering the hole on both sides and poke a hole in it for the pin to pass thru as normal. Also as good practice as others have mentioned is to check and tighten the #8 nuts in the diagram....a task easier said than done. You must climb (or have someone smaller climb) into the hatch under the starboard seat and use a long (2ft) extension on the socket and tighten the nuts, the port side with the batteries try a mirror and flashlight as the farthest one back you really need to tighten in the blind. The nuts tend to looses over time. Once you have the foam in and the tower back up just hit the base of the tower with your hand where it was rattling inside and it should be gone.
I have 2018 242x and one side of the tower rattles whenever we hit a wave. We checked everything and everything on the tower is tight. The part that is making it rattle is the plastic insert that the tower pin goes into. It appears that the plastic has been stretched and the pin no longer fits tight which causes it to shake. Anyone know if this plastic can be replaced? I can’t find it on any of the Yamaha tower parts diagrams. Picture attached for reference.View attachment 221940
Does anybody know the part number and/or name of the actual T-handle "Pin" that the OP is holding in this picture? I have lost one of those today on my 2018 212 Limited S.
