2019 242X Depth Transducer
Planepilot
HELP! Trying to locate the Depth transducer on the boat for replacement. I have a 2019 242X E-Series and I got the Communication Error message that others have posted. I purchased the service manual online but it is inconclusive about the location and replacement of the Depth/Temperature transducer. Any help would be greatly appreciated.
Remove the clean out tray and you will see it mounted in the bottom of the hull. You can also see a black part of the sensor if you look under the hull near stern.
Thank you for the help. I looked in that compartment but nothing seemed obvious. I probably need to unscrew the larger part of that panel to open up the space more than the quick access panel allows. Thanks again.
This is what it looks like in the hull
Is the clean out tray the large hatch under the sea deck in front of the engine compartment?
No, the clean out tray is located between the two jet pump clean out plugs accessed under the seats on the swim platform.
