2019 AR195 Radio/Speaker issue
tylerwillsey
Jacksonville Florida
AR195
Need help!
I have a 2019 AR195, speakers and everything worked fine,took it out the next day and had no sound, head unit is functioning properly, I have tried switching the inputs, changing volume, settings, no joy. All the connections on the back of the head unit seem good. I just charged up both of the batteries and that didn’t solve the problem either. I have 4 Polk Audio speakers in the boat, and 2 Rockford Fosgate speakers on the tower. So my question is how come I have power to the head unit but there is no sound from the speakers, happened overnight, battery was turned off like always and nothing changed from what I typically do to shut her down
FX195
Bradenton, FL
I had the same problem one time, turned out to be condensation on the wiring connections on the back of the radio harness. Disconnected harness blew a little air on it then sprayed with WD40, had my sound back. Have'nt had an issue since. Hope this helps.
BrandonG
Are you running the speakers on an amp? I would assume so if you added tower speakers.. Check the remote turn on wire for the amp maybe?
