2019 AR240 mooring cover question
Ben Stupendous
First post....
I'm having some difficulty with my mooring cover. There is a nylon strap that runs the length of the cover, and clips together in two spots, one on each side of the boat.
When I've got the cover on, I cannot clip both sets of clips together (I usually do the one next to the ratcheting handle last), as the nylon strap seems to be just a bit too short.
Has anybody else encountered this issue?
LayneG
I didn't have an issue with mine. I did have to let some slack out of them, but they buckled as soon as I did.
sfadchi
Wellington, FL
Mine fits perfect. Never had an issue. Make sure the ratchet straps are completely out before trying to buckle the clips.
HailMary
Finger Lakes Region of NY
On both sides!
Jeel
Toms River NJ
On both sides!
What he said , both sides need to be completely out...i put mine on while its on a lift over water(look at my avatar) , i cant get to the port side so i have to lean out to snap in the buckle , so far i havent ended up in the water
