2019 Scarab 165 Identity - Missing Bolt
bindiciani
HO Impulse
I have a 2019 Scarab 165 Identity and lost a bolt and nut during cruise on the lake this past weekend. As far as I can tell it is the pieces circled in red below. Does anyone know where I can go to order the parts or what it is called so I can search it correctly online?
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
The BRP part number on these diagrams is the correct part number. The problem is that they share a lot of parts with Sea-Doo which is way more popular to reference online. Knowing the equivalent part number isn't always easy. Generally, you look at Sea-Doo diagrams of similar engines and find the same part. That part is usually the identical part of BRP.
Otherwise, you need to call a Scarab dealer and get them to identify and order it for you.
bindiciani
HO Impulse
I took the picture from an older thread you replied to. In that thread you provided a path for another person to follow to get to the descriptions of the parts. Unfortunately, the bolt, spacers/washers, and nut that I need were not part of the list in the picture. Do you happen to know the path or selections I should make on the website?
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
Ah gotcha.
EPC.brp.com
Rotax
AJ (AA is the first engine year 2014 and onward, but this part hasn't changed at all on all years)
Your engine HP
The single cat -17ft option
Jet pump reverse gate
Hopefully that makes sense for you. I'm about to head on a remote canoe trip for 4 days. Leaving in an hour in case you ask for follow up help.
