2019 scarab 215 g wear ring questions
Kapem
215 G
New member here, what size wear ring is used for a 2019 scarab 215 g. I couldn’t find anything specific to the 215’s.
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
epc.brp.com to check Rotax parts in the future. Get your engine model number and you can drill down in the Rotax JPS parts.
Twin 150HP require a 155mm wear ring, BRP#0460661 or Sea-Doo#267000419.
Those two parts should be identical. I recently purchased the same one for myself as a spare. But I haven't installed it.
Kapem
215 G
Those part numbers bring up a 150 mm ring. Just an FYI. I was able to find 155 mm rings , so all is good
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
josh195
Indiana
How do you determine what model you have? I looked inside the boat and see "Model SB" and on the engine has 6 numbers followed by "AAA".
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
6 numbers followed by AAA is your model number. The AA refers to the year. AA is 2014 like yours. I think it's the first two letters of the three, but don't quote me on that since I also have a AAA. So when you select Rotax JPS in the pull down, then you have to select the two letters that match yours.
