2020 242X Maintenance Due Alarm?
Ric Moseley
Cedar Creek Lake (near Malakoff, Texas)
I got a maintenance due alarm for the starboard engine last weekend and don't know what causing it. Anyone know what the below codes means in the for the Starboard Engine? The port engine screen looks the same but it's not giving the warning (yet).
Hummm, I just got something similar on mine but it was because I just went past the 10hr mark and the oil needs to be changed per the owners manual.
That just may be a maintenance reminder for service at a certain time interval. Whats the hours on your Port engine? I'm sure the starboard engine has a slightly different number of hours, (like .1-.2) so it will probably have a pop up alert when that interval triggers. 2020 Yami, so probably near 100hrs or so on the engines? Just look up the hours and see if there is anything in your manual that corresponds to some form of maintenance like 100hrs, 150hrs 200hrs etc.
Just my thoughts. It doesn't look like something is wrong but more of a reminder.
That alarm is based on hours. If you go into system settings and then reset your maintenance schedule, it'll go away until next time. I believe it's a 50 hour alarm. But also, make sure you change plugs and oil!
