2020 275E oil change kit
Faraim97
275E
Can someone tell me the correct oil change kit part # for a 275e
I would assume it would be the same as a 195 but you need two. 1.8 SVHO engine correct?
This is the kit you use for the HO/SVHO engines :
LUB-WTRCG-KT-10
You need 2 of them, 1 for each engine. Spark plugs arent included in the kit.
(2) 4 qt 5w-30 of your choice and (2) filter of your choice. I've used ford FL910S filters before no problem or whichever filter that is equivalent.
no need to buy "YAMAHA" kit
If you are still under warranty I would buy yamalube and keep the receipts.
