2020 ar195s gps will not relocate to new location fix please
Tysonmartel
My brother inlaw had a 2020 ar195s and the gps will not relocate to a new lake. You can touch the icon on the screen but it will not recenter location
Wescoast
SX195
I have a 2020 ar195s supercharged 1.8 and my gps will not re locate to new lake it is stuck where I purchased the boat. Tried the bullseye icon in the top left of the screen and it does nothing? Is there any helpful advise anyone can lend me on this matter please and thank you.
212s
1000 Islands
212S
Contact your dealer - may be a GPS receiver issue?
marcham
Comox, BC
AR195
2 new accounts, same odd question, .... doesn't seem ligit.
Wescoast
SX195
I called the dealer they told me all they have ever done is hit the little bullseye button on the top left. Every time I hit this but it re locates me to where I purchased the boat. I disconnected the battery also tried to unplug the sending unit either of those two things worked.
Farny
Spring TX
Centurion
Maybe a software update would fix?
Wescoast
SX195
that is possible do you have to go to a dealer to do that?
212s
1000 Islands
212S
Yes the dealer would need to connect to the unit to update it. However I recall someone had an issue where their GPS antenna failed - it's the white hockey puck sized disk in front of the windshield. It's an easy item to get replaced, but the dealer would probably need to confirm before ordering a new one.
Wescoast
SX195
Thank you for the insight, is it possible that I need to re acquire the satellite I’ve read that if it’s been off for long periods of time then back on and moved it needs to be re acquired?
212s
1000 Islands
212S
No, the GPS system works on multiple satellites automatically...position acquisition time is based on signal strength mainly, so if you're parked indoors or under trees or power lines it may not lock or take a long time to lock. When my SUV goes through the car wash, my GPS signal is lost, but it's locked again about 10 seconds after I come out of the car wash. Out at the boat ramp with nothing overhead, my boat's GPS lock is virtually instant.
