2020 AR240 in Lake Saint Louis MO
shanes17
Lake St Louis MO
Good afternoon!
New jetboat owner here, purchased a 2020 Yamaha AR240 a few weeks ago. This is the first boat I have ever owned outright. Grew up around them, parents had one and grandparents as well. Spent a lot of the time boating the Ozarks. We are a family of four with a good sized dog, who I have yet to introduce to the boat.
We will be trailering most of the time keeping it in storage nearby, with the exception of a few extended weekend lake trips that will involve us using a slip. We have taken her to Mark Twain lake a few times so far and got to experience pulling the cleanout plug already once to dislodge some debris, hurray! ;) In all seriousness, it was a good experience as now I know what to look for the next time.
We plan to explore LOTO next (grew up on this lake so very familiar) and Tablerock later this summer. I would like to eventually take it down to the Gulf (Orange Beach area) however that will be a year or so down the line as I build up the confidence first.
Few questions that I have for you experienced vets :)
Do you take out your clean out plugs when you remove the boat from water for storage? Rather than letting them sit plugged in? I found a guy online who takes his out, sprays them with silicone spray and leaves them until the next time out. Basically said to prevent rotting of the rubber seals. Makes sense just curious if this is common practice.
Something else that happened to me recently, when backing the trailer into storage the trailer brakes kept locking up. I had to place the brake actuator lockout bracket into the tongue and secure it from falling out with a bungee cord because after placing it in then making any slight correction to the trailer, it would fall back out and lock up the brakes again, really not a fun experience after prior back-ins went relatively smoothly. I am concerned since this never happened prior and we have done this at least 5 other times without the lockups occurring or the need for the actuator. Am I missing something here?
Lastly, winterizing. I have researched this a bit yet still not sure which recommendation to go with. One poster I saw ran antifreeze through his flush lines which I thought wasn't necessary? Is it as easy as just running some fresh water through the flush line, blowing out the access then putting in some fuel stabilizer before storing for 6-7 months? We likely will keep it outdoor with the factory cover although we have a mooring cover, I've read the factory ones are better for the harsher conditions. I plan to take the boat in for the 10 hour maintenance ($400), trying to avoid the additional winterization cost this fall if possible.
Looking forward to mixing it up more on here and excited to share some adventures with the board!
Pic of our new baby:
Awesome, and welcome!!
Plugs out and laying on top of the hole sideways, lid should still shut, when not in water. :)
Loose or water logged connection with your trailer lights affecting your brake lockout?
Let us know when you head to Table Rock. There are several of us that seem to be frequenting the lake, this summer. Lol
Nice!! I have the same boat! I take the clean out plugs every time and get the water out of them, There is quite a bit in there, I’m in salt water so it’s a must to prevent damage and marine growth. I just set them back in with the dog ears not aligned so they sit on top of the smaller hole the fit into. I lock them back into place before I hook my trailer up to my truck so they don’t bounce around in there and do damage. I would recommend taking them out every time and draining them, and not locking them back in when not in use. my dealer (also seems to be verified by numerous posts asking for help on here) that the rubber can swell in the elements and make them a real pain if not impossible to get out. My dealer lubed them up at the 10 hour service, they did seem to go in and out much easier, so I think I’m going to make that a once a month job.
You got a 7 pin or 5 pin trailer connection on the tow rig? 7 pin should automatically override the lock when reversing.
Can’t help ya with the dogs, mine stay home, they are large and have no chill, my seats and boat would get ripped and scratched, hair would be everywhere, not worth the stress.
I think you are pretty much set for the winter plan, I would add some lube/protectant to everything that moves, pull the batteries, pull the carpet Incase any moisture gets in there, clean the inside and spray the seats with a protectant, put some gulf tees in the pee holes and dream about warmer weather.
As for the ocean, I recommend coming over to Destin FL, not to far from Orange Beach AL and has a lot of protected salt water to dip your toes in the salt life without any of the risk.
like @Inthrustwetrust said...if 7pin connection, should be locking out when reversing.
we have to use a trailer valet when we park the boat next to camper in our carport...we use one of these...magnet holds it in place
Hey guys, it is a 7 pin connector.
So then is that normal? My brake lights and blinkers are all working on the trailer, so it appears the truck is communicating with the trailer.
Any other suggestions? I find it strange that the other 4 or so times I backed the trailer in this never occurred.
Welcome - if you can replicate the brake lockout, then take it to the dealer and use the reverse lockout pin as a temp fix. I also recommend the above linked key, stays firmly magnetized to my trailer while traveling and serves as a nice alternative to the PITA factory lockout key.
Congrats on your new boat! I'm sporting a 2016 AR240, also my first boat. I love it!
You're getting the right advice here. Pull your plugs each time and leave them loose. Just keep in mind, you'll likely forget to reinstall them one if these times and find you have no thrust...
One quick PSA, we don't allow the public use of the "w" word (winter) until September. It's perverse and triggering. ??
Enjoy a fun and safe season!
I meant to add. I experienced this once for the first time this season. The connection to the the trailer seemed fine, the auto lockout just wasn't cooperating that day. It's been fine the 4 previous seasons and fine several times since...? Hopefully it's nothing.
Yeah spoke to the dealer, they thought I had a faulty connection on the 7 pin connector. Said its common and just to keep something around to lock that actuator in place when needed but just to make sure and remove it after backing the trailer in.
Thanks all for the replies!
