2021 195S Bow Roller?
bigd1634
195S
So I know that this topic has been talked about over and over. My understanding is that the replacement roller set for the Yamaha boats is the 3.5 inch Stoltz. I Ordered one and was told a day later that there is no more stock. I then looked at a few other sites and again, out of stock. Has anyone had issues with ordering these? I have heard of some using the 4 inch and either bending the arms out or cutting the roller down to fit. I would rather use the 3.5 that is meant for it. Has anyone used a 3 inch and added a few washers for spacing?
If the rollers are not available, has anyone had any luck with a bow guard scuff buster? If so did you get the regular size witha notch or the XL with a notch?
marcham
Comox, BC
AR195
Following ... this stuff is almost impossible to get in 🇨🇦.
CaTiRo
Alabama
I received mine several weeks ago. Are you all doing a google search for "3.5 inch stoltz bow roller"?
bigd1634
195S
yes, it is marked as out of stock through multiple vendors and I cannot locate it on Amazon.
DrPhil
195S
Ebay had a few of these, but note that it does not come with the side 'bells'. Hoping I can re-use the existing ones which should not touch much - or - eventually locate the bells.
Schil
195S
Any luck find them with the bells?
RobbieO
Sacramento River Delta
212SE
Here’s what I ordered, and also ordered 4” bells
bigd1634
195S
Yes a few days after the post they were back in stock. Had it a few days later.
Schil
195S
Hi. I’m in 🇨🇦 Too. I can’t find this 3.5 inch stoltz bow roller anywhere. Did you have any luck?
ll the US sites have them but will not ship up here.
marcham
Comox, BC
AR195
Nope .., I'm SOL....
marcham
Comox, BC
AR195
Is that a real business? No phone no, no address, where do they ship from?
Schil
195S
Not sure. I tho the same but I’m trying it out. Let you know if I get it.
Schil
195S
Hi did you get it in Canada? Or shipped here?
I ended up buying a 4 inch roller from Amazon and I just cut it with a oscillating tool. Worked fine.
bought the bells for it too.
Mauri_6
195 ID
Do you have any pics?
