I am looking to add 2 tower speakers, most likely Rev 10's, to my 2021 195S. Does anyone know if the tower will still fold down with the speakers installed?
Yep it'll fold down no problem with them installed. Wetsounds also has their swivel clamp system that makes the speaker super easy to remove if needed as wellI am looking to add 2 tower speakers, most likely Rev 10's, to my 2021 195S. Does anyone know if the tower will still fold down with the speakers installed?
Yea, my tower literally SITS on the steering wheel when it's down like that. I keep the steering wheel mostly up (in terms of tilt angle) all the time. Also, my tower LIGHTLY touches the port side window frame when fully lowered like that.
My modified AR190 Tower collapses to about 82in.What is the maximum height off the ground of the 195S on its trailer with the tower folded?
My 2021 195S with the tower modified is right at 82.5 inches eyeballed with a tape measure. The tallest point is the Bimini rod in the picture attached.What is the maximum height off the ground of the 195S on its trailer with the tower folded?
@Ozark I completely understand needing to stay off of @Hoyt 's build. He is always willing to help.
I routed it on the same path as the wire for the factory light on the towerHow did you run the wires down the tower at the fold?
Interesting that's exactly where mine are mounted, and are the same size and I just assumed it wouldn't work so I take that one off everytime before putting into garageUpdate: I ended up going with Kicker cans and 6.5 Wetsounds that match the oem speakers. It’s a very tight fit but they do fit with the tower drop mod. The kicker can part # is 12KMTESW for those curious. Shoutout to Creative Audio for the fantastic service.
I am running two wires that are pretty thick cause each of them are 16 ga speaker plus the TVs wires in one sheath. About 1/2” each. Will those fit through the whole? Also did you unhook your tower to do this?I routed it on the same path as the wire for the factory light on the tower
It’s an extremely tight squeeze and only works with the steering wheel in one position. I think one click up from the bottom but I can’t remember off the top of my head.Interesting that's exactly where mine are mounted, and are the same size and I just assumed it wouldn't work so I take that one off everytime before putting into garage
That might be tough. I’ll post some pics and explain what I did when I get home from work.I am running two wires that are pretty thick cause each of them are 16 ga speaker plus the TVs wires in one sheath. About 1/2” each. Will those fit through the whole? Also did you unhook your tower to do this?
The hardest part was getting the wires through the base of the tower. The hole is at an odd angle so it’s tough to push wiring through from the tower side without getting caught up at the “exit” hole at the base of the tower. It’s difficult to find a tool to reach in from the base and grab the wires because it’s a long narrow squeeze. I ended up running the left tower speaker wire down the left side of the tower.I am running two wires that are pretty thick cause each of them are 16 ga speaker plus the TVs wires in one sheath. About 1/2” each. Will those fit through the whole? Also did you unhook your tower to do this?
