2021 AR250 transducer communication failure. Lost depth reading.
Davyk
2021 AR250 transducer communication failure. Lost depth reading. Where is the transducer? What’s the most likely cause?
Transducer can be found under the clean out port tray. They are pretty easy to swap out. They fail all the time unfortunately. We do offer a plug and play harness to install an aftermarket unit like the DT800.
Thanks for the response! I may buy one. Is that the tray between the two clean out plugs in the rear of the boat? If so, I looked under that tray today and nothing that I thought would be a transducer stood out to me. Not sure what they look like but didn’t see anything with wires coming from it
. I’ll look again .
It's way at the bottom. Easier to find on the bottom of the boat (looks like a nice black disk) typically than from the hatch. Once you find it below, you can better approximate where to find it in the hatch. Usually a black cylinder with a couple of wires coming out of it. If you look in the stuff that came with the boat, used to be they would include a 'blank' transducer, which is the same size/shape that you can pull the transducer & put the plug in (because without the transducer it leaves a 1.5" hole in your boat). But if you have that, it will show you the exact size of that for which you seek...
Thanks again. I took the boat back out today and the depth indicator was working perfectly for about an hour until I got into some really shallow water and it failed again. I looked back down in the hatch and found the black wire proceeding from the transducer and followed it down with my hand as far as I could but I couldn’t reach the transducer…. but I looked under the boat when I pulled it out of the water and I could see it, I was reading online that sometimes on the AR 250 you might have to remove the muffler to access the transducer. I sure hope not. I’m just wondering about some simple troubleshooting steps before I buy a new transducer and maybe just cleaning the transducer on the bottom of the boat would help. Not sure if that would help but it might be worth a try.
Would not surprise me if removing the waterbox were required... That certainly looks like the cable I would expect (and I bet that label has the part number on it for the transducer).
Cleaning the bottom of the boat certainly could not hurt. Question: You said it failed when it got to shallow water--when you return to deep water, does it start working again? How shallow of shallow water is it where it fails? 1 ft? 0.3 ft? 5 ft?
