2021 Scarab 165 transducer transom install location
Bseltzer4
165 ID
Good day my jet boat friends, I want to install a garmin echo plus 44 transducer on my scarab 165. I want to kindly ask if anyone has recommendations on location of transducer on transom and any pics available would be great. Thank you in advance
ScarabPapa
165 ID
I have the same boat. I was wondering if there is an adapter harness to tie into the factory transducer already installed. Of course that would be too easy.
Bseltzer4
165 ID
Scarabpapa,
My boat does not have a factory transducer. Can you take pic of yours?
ScarabPapa
165 ID
Sure, when I get home. You should have a depth display on your screen. Open your engine compartment and look on the port side and you'll see a brown box the size of a pack of smokes glued to the bottom of the hull near the engine.
Bseltzer4
165 ID
Thank you my friend
I’m not sure if I have that. I’ll look. Appreciate the pics
shiptoshore
165 ID
Hi I have a 2016 with a factory transducer..did you ever figure out if you could tie in a garmin?
