2021 Yamaha 195S Connext Issues
Terri
195S
We have a 2021 Yamaha 195S purchased new August 2020. A few weeks ago we started having issues with the Connexts system. First started with error messages “communication error” then stereo intermittently would not connect via Bluetooth, connext display states media “locked,” then depth finder would not work and now continuous beeping without an error message being displayed ? Does/did anyone else have this issue with Connexts ? Any ideas on a fix?
Check the terminals at the battery switch. Likely that one is loose. Check by wiggling all connections and see if anything moves. If so, that may better be your culprit. This is a known issue and mine did the exact same thing. Other possibility would be failing transducer, although I would start with battery switches
