2022 252XE left tower speaker inop troubleshooting
Joshua Miller
Jacksonville, NC
252XE
Going through my fault isolation steps:
-left tower speaker inop. Makes a humming noise when volume is at zero but does not work at any volume stetting, with accessories or engine by running regardless of throttle position.
-swapped tower speakers, no change. Wetsounds sent me a new HTX-4 DSP amp, still didn’t fix it.
-exposed as much wiring as I could and did a visual inspection, no issues. Wire continuity checks out on a multimeter. Green wires are for the left speaker and blue for the right.
Can a bad ground affect one speaker and not the other? Anything else I need to check? 568BE135-EAFD-47F7-A8AF-C0277CA50837.jpeg6EDFB559-AE08-47ED-A9AB-D3BBDBE1DCAE.jpeg224467E3-C96F-4B01-8038-C39D1093C3FD.jpeg2278DBFC-5396-4006-8DB7-1382D46B88A6.jpeg
