2022 AR250 - replace bilge fitting
mike mews
SeaDoo
Challenger
I have a 2022 AR250 and need to replace the stock bilge fitting/nozzle with a metal one. Does anyone have experience accessing this area inside the hull?
Hoyt
Suffolk, VA
I did my 195s. Assuming your talking about the thru hull fitting (part you see from outside)? They are super easy to change out. You will have to climb inside your starboard rear compartment though. They'll be right there
JetBlasM
JetBlasM
Same fittings as this jet boat.
