212X JL Audio build
nate kennedy
Rochester MN
Nothing new or special just posting some pics of anyone is looking to do something similar! Set up is:
JL Audio M800v2 powering 8 JL Audio M3 speaker
2 stock bow location speakers
2 additional cockpit speakers
2 stock cockpit location speakers
2 stock transom location speakers
JL Audio M600 powering 2 M880 tower speakers and 10” IB sub
*edit M880’s briged for 200 watts per speaker and the IB sub briged for 200 watts as well
The only thing I notice is when the sub hits even kind of hard there is some flex sound in the fiberglass. I need to work on that and any suggestions would be appreciated
Thanks to @Earmark Marine for the package!
92EAE18D-2D8A-4524-8326-551ED46552A6.jpegC9AFE85C-B597-4A60-AC59-ECA617C564D8.jpeg223E766C-8C65-46F6-97B6-3C0A55E02BAD.jpeg6DE08FF3-8D56-49DC-A977-7C3950CBAEE5.jpegEAB2D9ED-7716-4C0F-BFAB-34B84ACF5C88.jpegEAB2D9ED-7716-4C0F-BFAB-34B84ACF5C88.jpeg323C5F42-924F-4FF0-96C3-675427C5288A.jpeg
Great Setup! Quick question, I know I would add the fuse as close to the battery as possible but I see your distro block close to the amp. Did you do both?
Nice setup. Are those JL speakers stock 6.5" size, or did you upsize those also? I also like your amp rack might borrow that also.
I have both. I have a breaker up at the battery and then the fuses for each amp. Hope that makes sense!
They are 6.5 speakers.. only the towers are larger. I had to open the speaker openings a little to get them to fit where the Polk speakers were. The amp board turned out better than I thought. Good luck with your build!
