Want To Buy 230 series compass
Livewire
Troy, AL
Limited
Took my compass off my boat after all the fluid inside leaked out. There was a couple on eBay when I took it off, but now the market seems to have dried up. Ready to plug the hole back up and not really wanting to put the old one back on. 676BCD63-21C4-4B15-8B59-5CE3389E1022.jpeg
Beachbummer
Houston TX
I was in the same boat (Pun intended, similar boat SX230) and found out the company that made the compass closed and sold the tooling, and they are not made anymore. I did not find a reasonable replacement. I ended up covering the hole with a white circle. If you find a good replacement let me know!
Livewire
Troy, AL
Limited
Will do Beachbummer.
atldude
Atlanta, GA
Wouldn’t an aftermarket flush mount 12v light marine compass work for you guys or do you have to have the OEM? :)
Beachbummer
Houston TX
For whatever reason, they are much larger than the oem hole.
