mrehmeyer
- Sarasota
- 242 Limited E-Series
towed my boat home after purchasing it with bimini up and no issues, towed out several times with no issues but decided to shift the cover from the lower position (front down slightly) to the upper position (slightly raised) and the cover came loose at 70mph... fortunately another car flagged us down and we stopped, only the light pole was holding it on. It had sheared through the wimpy front velcro strip and broke the wires from the solar panel but we managed to get it back on and I put zip ties in 8 places around the bar and over the strap so even if it comes loose, it shouldn't leave the bar...
I had never thought to check if the strap had loosened over time, but going forward I will add that to my checklist and if traveling at speed will tilt the cover forward to prevent any lift from passing wind.
