242 limited S E-series 2016 rear swim deck radio doesn't work,geteway error msg,fuse 20 blown
SEBEK
SEYMOUR ,CT
Limited
Please help on my last trip my radio stopped working gateway error msg on connext screen.Middle 20 amp fuse on battery port side was blow .I was hoping it's just fuse but after replacing fuse blow immediately
There are a few things on that circuit including the power outlet i believe. You will need to see what else is on that circuit and start unplugging them one at a time and try a fuse after each one is unplugged.
Neutron thanks for advice I find the reason of issue.
Somebody forget disconnect gfc from 12v outlet and the water make shortcut.
Yupi error gone radio work
