Thom
- Lebanon, Oregon
- 242 Limited S E-Series
@HELP Houseboating on Shasta Lake and having some issues with my 2016 242 LSE
History: Boat has 120 hours, regular maintenance. Intermittent Connext ERR GPS speed issue for the last two seasons, finally fixed when dealer replaced port side tach last week.
Two weeks ago, after floating for a couple hours starboard engine wouldn’t start, Connext error ‘check engine drive control’. +/- buttons would work in no wake mode, throttle levers did nothing, moving full forward, full astern had no effect. No obstructions/blockage, impellers felt fine. Rebooted a couple times, and starboard engine started. Still wouldn’t respond to throttle inputs. Limped to the dock and loaded up. Pulling out error message was gone, engines seemed to run normally.
Took it to the dealer so they could replace port tach. Mentioned the issue, they water tested and everything checked out. No stored codes.
Launched at Shasta Saturday. Verified GPS Connext error resolved. Went out yesterday and cruised for a couple hours, never WOT.
Got up this morning to get fuel and go boarding and noticed starboard engine wouldn’t rev past 6k when attempting WOT. Headed back to the houseboat to diagnose. Cooling outlets both flowing water as usual. Grates and impellers clear and feel undamaged, no obstructions. Both batteries have 12+ volts when completely disconnected. Oil level fine, air filter unobstructed. Starboard engine missing on cylinder 1. Swapped coil packs and plugs, same results. Plug looked ok. Jiggled wire harness and cylinder stared firing. Opened up harness wrap to inspect, no obvious issues. Applying pressure on the harness at the coil pack consistently allowed cylinder to fire normally. Removed and reseated pins in connector, no change. Swapped plug/coil packs back to original placement. Reconnected batteries and turned boat on - error message ‘check engine drive control’ and starboard engine doesn’t start or attempt to turn over.
Starboard tachometer LCD display flashing distorted pixels. Disconnected it, still no start. Disconnected port tach to confirm engine would start without tach connected. Reconnected everything, still no start. Diagnostic display first reported error code 183, now shows 186. Disconnected batteries for several hours, rebooted several times, still no start or attempt to start.
Anything else I should try? I’m wondering if I have more than one problem here - perhaps a harness issue and an ECU and/or tach issue.
